Sunroof seal on 1983 GX
Got a new seal but don't know where to go from here. Please help!
image.jpg Hi there,
Ive recently got a new sunroof seal as mine is all perished. However I have no idea how to get the old one off yet alone fit the new one. If anyone could help that would be great! Many thanks!
You need to remove the sunroof, there should be a guide in the haynes manual or there may be some on the web.
It was years ago when I last removed a sunroof from a golf I used to own so can't be much help, but you need to slide back the inside cover to get to the screw/bolts to get it out…
pull the leading edge of the inner trim down to unclip. close roof, slide trim back. all the roof panel fixings are then accessible :)
