Suck or Blow
(In Topic #205705)
Mine is blowing and I reckon it should be sucking. If it is turning the wrong way, I assume that I simply turn the connector round effectively swapping the wires round?
I also noticed that on the fan motor is an arrow which points in the opposite direction to the rotation of the fan.
But if it's meant to blow, I'll leave it alone.
I assume that if I swap the wires over (ie turn the multi plug over / around) that the fan will turn in the opposite direction?
if its an earlier one with 2x spades just flip them the other way
thanks for the advice though - much appreciated
Mine also had the lockign tabs so it should only fit one way. and yet, the chump still managed to force the plug on upside down
thanks again
So is that a suck or blow?
Having cut n shut the wires, Mine now sucks.
Last edit: by RichieS
Oh…. it is on, that's why it took me 2 hours instead of 30 mins to get home on Wednesday…
