Starter motor connectors
(In Topic #232278)
My old starter motor seems to have one more connector (pics soon). Is this something to do with Klockwork Jet fuel injection? Fifth injector? If so, what do I do about it?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Alrighty.
The offending terminal can bee seen here:
It forks into 2. One side goes towards the engine block, forks again, and seems to go to 2 points on the engine.
The other side goes to this chap:
Whip
/wip/
Noun - Car
/wip/
Noun - Car
rubjonny said
yep the other feed is pin 15a for the 5th injector. you can tap it to a cranking feed if you disable the cold throttle enrichment valve if fitted (metal cylinder on the rear of the airbox) or fit a diode in the wire to prevent the cold throttle system engaging the starter motor whenever you boot it
for an easy life just buy a corrado 1.8 16v starter motor, it'll swap right over and has the spade connections you need
Does this mean I just need a diode, then I can attach the spare wire to the main positive terminal?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
