Spark then no spark?
(In Topic #215278)
Getting 2 or 3 sparks then nothing until I turn of the key and back on
Hi as the title I have a 1.8 DX golf convertible
I have the plug out for testing, when I crank the car I get two or three sparks then nothing after that,
If I turn off the ignition and turn it back on I get the same again two or three sparks then nothing
Any help would be greatly appreciated
William T Whyte
'74 Beetle
'82 Mk1 Golf
'08 Mk5 Golf
'74 Beetle
'82 Mk1 Golf
'08 Mk5 Golf
do you a spare distributer ?
is the dizzy cap ok and rotar arm
is it the same on all 4 plugs
just a few things I can think of
no expert though
no expert though
I don't have a spare distributor but I have changed the roto arm and the cap looks ok, maybe I should get a new one tho,
I ordered a new TCI also
William T Whyte
'74 Beetle
'82 Mk1 Golf
'08 Mk5 Golf
'74 Beetle
'82 Mk1 Golf
'08 Mk5 Golf
I have the same issue. 2 sparks then nothing. Did you solve this problem?
How old is your rotor arm and dissy cap and HT leads and spark plugs?
If more than 12 months old I would replace them 1st to see if that helps…
Cover the open bonnet of the car with a dark blanket.
Have some one cycle the ignition switch and while they do that you get under the shrouded bonnet and look for
Sparking Fairies dancing about your HV leads. If you see them, then use sand paper to buff the area, and continue. Common ares on these that I have found are the metal jackets to the block.
