Side lights and running lights gremlins
(In Topic #234794)
So does anybody know where or what is a good starting point to fault find this gremlin? From the LED being blown I'm am assuming that there is too much current possibly, so a short somewhere maybe? Any ideas would be helpful thanks.
Update: just found this guy hidden down in the black sleeve. Looks after market me thinks lol. Looks like it connects grounds from washer bottle pump, running light (+bumper light) and headlight and also the smaller inner headlight on the grille. In the bentley manual it looks like these should NOT all be connected. Where are the headlights supposed to be grounded?
Last edit: by Shubbs
Head Lights high and low are the same, side markers and washer motor are separate.
Check to verify that your Battery to frame and frame to engine grounds are good ( 0 ohms) or less than .5 Voltage drop.
Relaying your highs and low are a vast improvement, and usually makes your bulbs brighter as the current and voltage increase.
Make your new grounds to the Frame with Self Tapping sheet metal screws, and buff the paint to clear metal use ring connectors and Solder them. After tightening the screws, spray the connection with battery corrosion paint.
For the rears I added new grounds to the tails, and side markers, tied and soldered to a large ring connector that I attached to the Bumper bolts.
Last thing was the marker light sockets, to clean them of all corrosion.
1) I'm checking grounds now after I found that beast.
2) battery is currently disconnected but did the old vinegar trick to clean up the wire for -ve like you mentioned previously. That is sitting at 0.9ohm. but think that is probably from my leads on the meter. How you check the volt drop? Battery +be to battery -ve then battery +be to chassis?
// UPDATE: 0 volt drop from connections mentioned above.
3) yeah I have a relay kit for the headlights and was going to start on that but wanted to figure out this gremlin before I start making changes so I know I didn't create a problem you know. What you think?
4) sounds like a good plan on the tails and side markers.
5) already cleaned all side marker lights.
Like I said everything worked perfectly for first three mins and then new LED bulbs started to pop and go out one by one. Like burning out.
Where are the headlights and side lights/marker lights supposed to have been grounded originally? Where that green connector for the grounds I only seem to have one brown that comes thru the cable way that's routed under the radiator. This is passenger side. On driver side the headlights both high and low and sidelights etc all have individual grounds three grounds on that side and only appears to be 1 ground on passenger side?
Make sure you have the proper wattage for the bulb.
You can even go LED for the rears, and don't have to worry about current flow. For the turns you may need to add the resistor to them.
Bulb numbers
Cabriolet Bulb Replacement numbers | Volkswagen Owners Club Forum
Tail light
5007
5007LL Long Life
Stop light
7506
7506LL Long Life
Rear turn signal
7506
7506LL Long Life
I would look at the LED replacements, as they last longer, usually as bright, and lower current.
i used these for the bulbs…… https://smile.amazon.com/dp/B07GDC2LHP?ref=ppx_yo2ov_dt_b_product_details&th=1
now thinking to try these…… https://smile.amazon.com/AMAZENAR-2-Pack-Extremely-9-30V-DC-Replacement/dp/B07KP7VJZX/ref=sr_1_15?crid=L7XNP6JF6CQ6&keywords=5007+led+bulb+red&qid=1649281575&sprefix=5007+led+bulb+red%2Caps%2C78&sr=8-15
or these…. https://smile.amazon.com/AMAZENAR-Extremely-9-30V-DC-AK-3014-Replacement/dp/B06X6DMVY3/ref=sr_1_7?crid=L7XNP6JF6CQ6&keywords=5007+led+bulb+red&qid=1649281575&sprefix=5007+led+bulb+red%2Caps%2C78&sr=8-7
am i missing something here……… seems like any of the LEDs should be fine, including the first ones that blew. No idea whats going on.
You usually don't need colored bulbs, unless you are using clear tail lenses.
Also you may need a LED flasher to use is you have the turns converted to LED, or add the resistors to them as the package that I read stated:
NOTICE: The 50w 6ohm load resistor or flasher relay might be needed to prevent the hyper flash, malfunction ortrigger warning message on dashboard. AMAZENAR LED are strictly tested for sale!!! We offer fully " ONE YEAR " guaranteed for manufacturer defect.
