side light and tail light out (resolved)
(In Topic #206724)
hopefully an easy one for you. i'm working long hours just now so not had time to diagnose.
had a quick look at lights yesterday evening and the nearside front side light and rear tail light are not illuminating, both bulbs are good but no power.
i suspect its a fuse, can you share your wisdom so i can fix quickly?
Last edit: by zorg
i pressed the little red button
http://www.clubgti.com/showthread.php?219775
ill check out fuse no 7
the mot guy put a new sidelight bulb in it (which was good of him)
but he didn't put the holder back properly and it wobbled out and earthed blowing the fuse in the process.
thanks again jonny!
