Servo part number check ...is it 9"??
Can anyone help…
192 612 105E….   is this a 9" servo off an early 16v Corrado as I am being told or not?
yes its a 9" servo. its probably not off a corrado one as it has a mk2 golf part number, but the mk2 number you have there has been replaced by a corrado/passat 9" servo number
Cheers John…it just turned up and is indeed 9" and in good condition….chuffed  Will it mate up with 23mm master cylinder from Mk3 ok?
it depends which 23mm it is, often the mk3 23mm abs ones have the holes offset diagonally on the MC so they wont fit mk2 type servos
