Seat slide latch
(In Topic #211258)
Hope that makes sense, Ideas welcomed?
pics as said, we should be able to confirm what they are for you at least.
Last edit: by Timmay Zoom Zoom
some images, hope they work
I hope that gives you the images to help you identify, car was in garage, limited angles available. Sorry about the dog!
easy enough to swap the handles:
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Fhow-to-convert-mk2_2
Sorry its off the caddy forum, couldn't find it on here
Should have it back on the road in the next few weeks after a long stint. Excited!
The horn failed so have brought a new one and the reverse lights not working but when direct connected light comes on, so have got a new switch on order. Whoops the bills in parts are racking up, but its been fun! No labour costs.
Also going to give the brakes a work out as not been used for a while so will whip callipers off and extend pistons and retract a few times and get the rust off the disks. (And change fluid at the same time. Then its MOT!
Both types used slightly different seat glides at the rear legs.
I would make an assumption that your frame would require the "Cabriolet" style of kit.
The front is 435881203A for the front only.
outer is 171881213B
Kit.
https://www.vwheritage.com/171898881-seat-guide-set-for-front-seats-mk1-2-golf
