Sealant type...
(In Topic #205238)
The Door Seals are pretty much peel off, and may be glued with a Urethane or Black RTV, I used Spray contact cement on the Seal at the bottom of the door.
The Upper Black Vinyl Cap on the interior is Only lightly glued it is very brittle and taking it off without using a scraper or thin Putty knife. You have to remove the inner scraper and door card as well as the door lock button to remove it.
Have fun, as I just redid my seats and cards last week, I had to rebuild the foam for the seat as those bolsters do get some wear.
From this:
To this:
The seats were really showing their age.
I was really tired of the White Interior and top so I am changing it over to a Tan Canvas top and Headliner.
I did find a SEM vinyl spray that matches the interior so the Headliner and Boot Cover are going to match as well as I have seen replacement boots, and they aren't made as well as the originals.
I re-Dyed the seat prior to the vinyl giving out and it lasted about 8 years before it started to show through to the aged white vinyl.
HOW-Tos to a point
Repairing your Seat bottom Bolster foam.
http://volkswagenowner…foam.?p=662258#post662258
Removing your Head rest to remove or replace the cover.
http://volkswagenowner…er-it?p=662274#post662274
Removing your Seat Back cover to repair the Bolster.
http://volkswagenowner…ters.?p=662282#post662282
How to remove a door card and adjust the window and stop.
http://volkswagenowner…rd-and-adjust-window-stop
