Replacing Battery Terminals
(In Topic #215747)
Appreciate your thoughts…and a happy xmas to all when it comes….
Regards
Kelt
Well 15 to 20 years at least.
But if you're having to constantly take them off and on that's a different matter or course. Not sure how long the new type will last under those circumstances.
My Cabby for example is 27 years old which I bought back in 2012.
I take mine off maybe 4 or 5 times per year including putting it away over winter. But they clean and treated with copper slip. 👍🏼
Sent from my Smartphone ☃️
It's probably worth getting a new main earth strap too whilst you're at it.
Not used the quick release ones, I'd think they'd be a bit too loose over time.
Ian
for the negative grab 2 mk3 cables, and dont forget the bolt with wee stud on the end on the gearbox it attaches to you'll need to swap that over.
cut the 2nd cable down so you have a length of cable with 2 ring terminals, 1 end to the bolt on the chassis leg the old cable went to and attach the other end direct to the battery or the middle ring terminal on the 1st mk3 cable with a nut and bolt
