removing the slack in drivetrain?
(In Topic #207503)
too much slack between accelerating and foot off the gas
However, there is quite a bit of slack in the drivetrain between accelerating and then foot of the gas.. it's feels like the engine and gearbox have two much travel between them and they catch each other up to engage.
Is it engine mounts or something or is it something internal?
thanks for any info or suggestions.
A hint
On the front mount (radiator) under the Cup that holds the mount to the tranny. Between the Cup holder and the valance beam place a couple of thick washers between the Cup and the Valance, this will force the rubber mount tighter on to the cup, and cause less torque loss from engine twist. It also helps keep the Drivers side mount from early demise, as well as slicing a chunk out of the old mount (drivers side) and placing it in-between the rubber and the steel mount top that way in the future when the mount goes south, the engine won't drop significantly and screw up the shifting.
I would suspect the rear and front tranny mount first.
A good way of beefing up the standard rubber mounts is to fill in the gaps with a strong mastic or pack it out with similar density rubber. This way they will last longer, be a little bit stiffer but wont shake your car to pieces !
Some of the poly mounts are almost solid which is good for performance but if it gets a bit tiresome after a while. A bit like rock hard coilovers, good idea at first untill you have a bad back and your teeth have fallen out lol !!
Jake Snelling said
Some of the aftermarket mounts are very stiff giving you more vibrations in the car.
nice info… i think i'll go with stock… i need my teeth at my age and my back is ruined already!
cheers fella!
