REMOVING FRONT AND REAR SUBFRAMES
(In Topic #208485)
Jacking Points
im going to be removing all teh subframes so i can have them powdercoated.
where is the best place to put 4 axle stands?
thank you
adam
Chairman
There's jacking points (at the from) by the sills, just use some wood to avoid damage.
When I dropped my rear beam I used some blocks of wood between the floor and the sill, it's not the most secure but avoided any damage, I believe there's jacking points right at the back, at least there is on cabbies!
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
I found using axle stands lined with some thick carpet worked a treat and did not damage things at all.
Try to have the rear of the car up as high as possible to make access easy….and use plenty of plus gas on the bolts for a few days before removing.
Chairman
Follow us on:
Follow us on:
Chairman
Follow us on:
Follow us on:
I would not work underneath a car without them.
