remove spot-light Grill adjustment screws
(In Topic #216984)
is it possible?
Hi,
Is it possible to remove these screws? and are new ones available anywhere?
regards
KP
regards
KP
Yes.
oh you wanted a how to?
step by step.
Gee
Did you try the link in my signature?
You would of been redirected to the Archive section,
Ho-to's then to briano1234 digifant how-to's.
or see this link
Cabriolet or Quad Grille Hi-Beam Removal | Volkswagen Owners Club Forum
step by step.
Gee
or see this link
Brilliant once again Brian. I’ll check that out tomorrow. Thanks.
If you're talking about the 3 long adjustable screws that mount the lights and then you turn them in or out to adjust the height.
I found a company in France that had them NOS.
It was about 5 years ago but if I can find that post I'll drop you a line in the off chance they still have them!
Sent from my Smartphone
Yeah that’s them. Although I think there’s only 2 per light - for the inner spots. Vw heritage are out of stock. Thanks.Golf Cabrio said
If you take them out and clean them up they work just fine.
There is a Hardware store that I go to that has the long oval headed metric bolts over here…
Struggling to pull them out from the recess. Any other tips ? I Want to avoid breaking them…Briano1234 said
Yes.
step by step.
Gee
or see this link
You Pry out the screw receivers that are in the plug.
Using Pliers to move one or 2 if the tabs in then pry them out.
Briano1234 said
Thanks Brian,
Managed to get them all out - one of the plastic retainers bust while pulling it out . It was mangled anyway so I need one replacement. Neither Vw heritage or classic vw have any. Anyone know where I could get one? Also quite keen to replace the ball headed screws with stainless steel ones. Would anyone know the thread? And/or where I could source them?
Thanks.
So did you sort this and manage to get hold of some replacements?
If yes where did you get them from as I cant find any replacements anywhere!?
'84 MK1 Golf - View topic: Humble Beginnings........... - VW Golf Mk1 Owners Club '99 MK4 Golf
