Refitting window guides
(In Topic #234397)
My window guides (3-door tintop) were removed by the body shop for painting - I’m now trying to get them back in but struggling….
Anyone re-fitted these, and can recommend how they go back in? I’m resigned to the fact that they’re going to get scratched and will need re-painted once fitted - I just can’t figure out which way to fit them into the door without them snagging…
If it's the ones I'm thinking off - the black uprights ?
I opened the gap up between outer door skin and inner panel with a little bit of wood/doweling , and then it spring closed back up again when I removed the strip of wood.
Regional Host NE
sure they go in turned 90 degrees
then turn back when the tab is just
below the channel
below the channel
Thanks!
below the channel
Thanks! I did think of this but didn't think there would be room to rotate them at the bottom of the window opening
