Rear beam/axle nuts
(In Topic #217788)
Consider yourself really really lucky. The VAG gods were smiling on you, I have hear horror stories on those bolts with folks using Sockets and a Ratchet and Searing them in twain.
I usually suggest soaking in a penetrant for days then only using a air impact to remove them.
But going back Never-seize……Shoot I bought a 1 pound can and it lasted me about 12 years, I am on the 2nd can as I type.
ps. You can coat them with Never-sieze, wrap the threads with Teflon tape then never-sieze again….
When I don't use never-seize I use either Yellow or White Teflon tape.
If you want to coat them after never-seizing wipe the bolt and nut devoid of never-seize and use that plasti-dip spray. Just mask off what you don't want covered.
Did you see I said Never-seize…really good stuff to prevent the nuts in the future from happening to rust…
Over here we have Copper or Silver Never-seize, some call it anti-seize…I call it magical, kind of like a Thermos Bottle keeps cold things cold and Hot things hot…how do it know which is which,,,,it's magic
When I use it on suspension parts or frame parts, I am not easy with the stuff, I slather on a generous coat to fully coat every thread….. I had an alignment guy say once, I wish every shade tree mech used that stuff, but you could go easy on it…. I said naw, I gots a whole bottle and I ain't cheap.
Last edit: by Briano1234
