Random wires in the engine bay
(In Topic #215076)
Merchandise Manager
Does anybidy know what this relay does or if it is supposed to be there? It has 4 wires coming off of it, i have figured out battery and earth. 1 goes into the car by the looks of things and the other goes behind the engine.
There was an cheap aftermarket alarm on the car when I got it that didn't work, so was wondering if this is something to do with that. Would really like to get rid of it
Follow the wires and see where they go? The red wire going to the relay may be one that should go to the coil, is there a none standard wire going to the coil… I'm not very good at electrics so check before doing anything, rubjonny or Briano1234 will properly know.
By the way your strut top mounts are shot, that's a big gap between the metal top and rubber so might be worth changing them sooner than later, Febi are the ones to go for as I've just tried some Meyle ones and they lasted all of 12 months before they looked like yours!
Merchandise Manager
The top mounts are brand new the car is on coilovers. They have sat like that since I fitted them.
Merchandise Manager
you could bag a VW relay holder and clip it above the fusebox, run fresh wire from it direct to the starter thru one of the spare holes in the bulkhead for example
