Radiator electrical connection?!
(In Topic #233809)
New vs old
Can anyone advise:
What does this connection do?
Do I need it?
If not, how best to delete the wiring?
Does the new rad not have anywhere to screw the switch?
Early-1800 said
Different rads can have the hole for the fan temp switch in different places, some near the bottom some nearer the top.
Not that I could see, unless the plastic circle at the bottom left in the below photo pops out?
Rad is part number 321-121-253/AL, which Heritage double-checked and confirmed is the right one…
Can you get some better pics?
Early-1800 said
does it look like it has a threaded insert in it?
Hard to tell. Im going to take the rad out and see if its a temporary blank plug that protects the temp switch. connection. Ill take more photos then.
Easiest mod to make on your fan shroud is to trim the metal tangs on the hose connections to make it way easier to install or remove.Early-1800 said
Result, are you not re-installing the cowling and fan?
Radiator shroud.
Marked for the cuts on the tin.
After making the Cuts.
Makes it easier to get on or off.
Easy when you know how/are looking in the right place!!
Yes im re-installing OEM cowling and fan, just waiting fixings.
Radiator shroud.
Cheers Briano, ill take a look at that
