Questions about spot lights
(In Topic #219054)
I have a convertible mk1 golf rivage 1993 (June)
1. Where would you buy spotlights from? I'm looking for original looking lamps (They have the longer 30mm brackets). Part number 155 941 783 and 155 941 784
2. VW Heritage have some but I'm afraid they will look too aftermarket. Has anyone got any experience of them?
2. What does the letter at the end of the part number i.e. C/D mean? I think mine is a C but the label is worn here.
Thanks,
Ali
2 ways to clean the lens,
1, heat them up and remove the glass, clean out and then re-seal the glass.
2, clean through the hole in the back with a cloth on a stick.
I think there's a how to on this site….
This will only work if you are replacing them because they have gone cloudy…
2 Phillips screws in the middle and 2 on each corner under the cap on the grille corner.
Turn the Grille so the light faces are pointed down.
Remove the Rubber boots, and disconnect the wires and remove the Bulb.
Boil some water or get really really hot water.
Crush 2-3 denture tablets into each lens, add hot water to over flow. Let sit over night, rinse well, add more hot water and let run out. Gently use a hair drier to heat the lens and body to evaporate the remaining water out.
The lens is actually cracked so I'm tempted to remove the lens. I bought the wrong spot light (shorter bracket) however the part number on the lens is the same so may use this.
Thanks again,
Ali
Just check the pattern on the glass is the same as VW did fit fog lights as well as high beam lights in the grill.
