Pin removal from headlight switch
(In Topic #222066)
Can anybody tell me how I remove this pin from the main headlight switch?
And can I buy a replacement pin?
Yes, and Yes.
insert a PIN or small Jewlers screwdriver in the recess under the main pin and pry it up that is the Keeper, once the keeper is out of the lock you can pull the pin and the wire out the rear.
Most parts places that I go to on this side of the pond have pins in the "Help" section.
Last edit: by Briano1234
Top man. Thanks Bri 👍
Regional Host NE
ouch be carefull straight
through the finger even
worse behind the nail
