Pierburg carb coolant leak
(In Topic #215699)
Leaking coolant from choke body
I seem to have a minor leak from the choke body of my 1.8 auto cabby. Hose changed so not hose. What is the best thing to do ? Take off cover and try and seal with some sort of gasket seal ? If so can I get away without draining system ?. Change carb to Webber ?
if its leakign from the choke the seal between the 2 halves may have gone. you can remove it from the carb it wont leak any coolnt iirc you undo the bigger bolt in the middle then it splits in half
Cheers Rubjonny, I have taken it apart and used gasket seal to try and sort it. Not sure if there was supposed to be a seal there but does not look like it. Hopefully this will cure.
