Parts missing from air box
(In Topic #218520)
Current rides:
I have just walked in from the garage and the bonnet is still up so a couple of pictures of my 1.6 gti air box.
The lead in air intake goes to a snorkle on the bumper.
The one out the rear goes to the heat riser on the back of the exhaust manifold with pre heat exchange hose.
I plugged that off using a cap off of a Radiator jug, and siliconed it in place. I capped off the vacuum hose on the Throttle Body.
From cabby-info.com
As a matter of fact I ran Pre-heater hose off the front hose port to the back of the grille so I could ram air into it. I wire-tied the hose to the grille and to the port on the
box. There are threads on how to dremmel it out and get it about 1 inch bigger, then duct the air off the grill in to it
https://www.reflectionsandshadows.com/digi-cold/
Oh and you are missing the MAF sensor and intake tube to connect it to the throttle body (expensive.) I know I had one that holed.. I have a thread on how to look for and repair a holed air intake tube.
Last edit: by Briano1234
