Over fueling 1.8t
(In Topic #205295)
Usually Filler neck rusted or vent hose loose, on the Gravity valve, or the Sending unit seal.
With injection Vacuum leaks and then timing, and Duty Cycle adjustments go a long way to keeping it running right.
Now with the Injection there are 2 types CIS and Digifant
so CIS has stainless Steel covered injector lines from the airbox to the head.
Digifant has a fuel rail and the injectors are inserted in to it.
Each type of injection system has quirks, so knowing which type you have assists us as well.
