Oil Pressure Sender / Center Console Oil Pressure Gauge
(In Topic #236979)
Also when i turn the ignition to run, the gauge pegs out and then returns to zero. is it supposed to do this? Kind of like a gauge test to let you know the gauge is working. But it doesnt read the pressure. and doesn't peg out when the blue / yellow wire is removed to test it.
Also when I start the car the gauge pegs out. So something isn't quite working properly. Any ideas or pointers in the right dir ction would be appreciated.
Last edit: by Shubbs
Shubbs said
no its a 1.8L engine. JH code. Car came with it……….not a mod by me.
you need to trace the wires, the factory loom wires will run to the MFA/cluster for oil temp and warning LED/buzzer, not to run a pressure gauge.
There are loads of wiring diagrams on google to follow
But are the wires in the proper location on the sender?
Blue/yellow is the Oil Pressure sender side, where the yellow is the on/off pressure switch that lights the dash.
I also found out that the sender is labelled 'G' and 'WK'. The 'G' is the blue /yellow in the engine bay and the 'WK' is the yellow wire. 'G' is the gauge wire, 'WK' is the warning light.
So long story short the blue/yellow in my engine bay didn't ohm out to my blue yellow at the gauge. So I pulled the knee bar back out and managed to see the tail end of the yellow/red jumper connected to the blue/yellow for the gauge so I pulled that connector apart so I could ohm out from the blue/yellow connector there to the gauge. So that ohm-d out fine so then checked the yellow/red jumper from the same connector to the engine bay. That did not ohm out. So I then pulled the fuse box down and started hunting around for the other end of the yellow/red jumper wire. Now during that search I accidentally found a blue/yellow connector not connected to anything so just thought I would ohm that out with the engine bay blue /yellow connector and low and behold that's the wire. Which wasn't connected to anything. So I then tracked down the yellow/red jumper connector and found that I had that connected to my fuel pump / sender wires which happened to be RED/YELLOW not yellow/red so I disconnected that and connected it to the blue/yellow jumper and hey presto all working now.
Sorry for the long story but felt it was worth the explanation. Silly mistake really but hey ho such is life.
I'm on to the next issue now which is a darn freeze plug leaking!! Aaaarrrgh!! Brand new plug and total pain to access!!
