Oil light flashing KARMANN cabriolet 1.8i 1993
(In Topic #211034)
Fitted VDO guages and new pressure sender
Can anyone help me please I've fitted VDO guages they all seem to be working fine getting between 4.5 to 5 bar on cold start then goes down readings seem fine. Butt I took the for a drive today and notice every now and again my oil light flashes 3 or 4 times then goes out.
I've fitted the sender to the side of my block I'm not a whizz at stuff like this I'm thinking the issue may be the oil sender do I have the right one not sure this is what I brought
Any advice please
Any advice please
Golf 1993 clipper
Audi A3 S line Quattro
Or do I just need to move it to the oil filter housing it says 0.5 to 0.30 on the sender
Golf 1993 clipper
I have an '83 1.8 GTI tintop and originally I fitted mine to the oil filter housing but suffered from the oil pressure alarm going off once the revs went over 2000 rpm. I fitted it into the side of the cylinder head and it has worked fine since. I think the oil filter housing is a higher pressure than the head.
What weight of oil and filter are you using?
Does it flash at idle only or when you are driving down the road?
I have one fitted to the side of the head as they normally are, but I also have another on the oil filter flange.
BTW All Cabriolets are Karmann Editions, as Karmann is where they were built from the ground up.
as in Ghia was the designer, and Karmann was the assembly plant hence Karmann Ghia.
all you ever wanted to know www.cabby-info.com
I've never had this problem before only since fitting this sender foe VDO few days ago does anyone have a link to the one I need just incase I have the wrong type
I noticed the light flashing 3 or 4 times when I was driving yesterday.
Then when I got back to my house it was still doing it at stand still it's not constant just every minute or so flashes 3 or 4 times I waited for the engine to cool checked my oil and everything is fine and I never had this before the sender changed
Golf 1993 clipper
Never answered the question on Ol Vis and filter type.
The sensor or sender is pn 035919561
Sorry Briano I think I've sorted it now cheers for help though dude.
Golf 1993 clipper
Hi, I'm having the same problem with my tin top, how did you manage to sort it, if you don't mind me asking? Thanks, Joe
Hi mate this is what worked for me after speaking with rubjonny on the site the problem was coming from my new sender with twin pole so all I have done is use a Tpeice put old one back in and the new one on other end seems to have sorted it so original wire is going to original sender for light then new wire going to guage sender I've had all my reading checked and they are spot on
Hope this helps
Hope this helps
Golf 1993 clipper
Hope this helps
Thanks mate, it put the fear of god into me the other day when I was travelling down the M1 at 65 and it starts flashing away! Will get my electrically minded mechanic guy to do what you said…I'm only good and cleaning it and driving it haha!
I was told.by mine as long as the pressure is OK on the guage from cold start to running warm /hot then there shouldn't be a problem he seemed to think that the guage was more of a true reading than a red light as long as your oil is OK and topped up did it flash before you fitted sender mine didn't
Golf 1993 clipper
I bought the car with the VDO fitted and and it started doing it the other day.. I hadn't noticed it before but car has stood for a while so not sure, got my guy on it anyway so I'll let you know if what your said resolves it, fingers crossed. Gonna do an oil pressure test i think to put my mind at rest!
Ye cool pressure test will put your mind at rest
Golf 1993 clipper
Let me know if you do anything different to fix it always good to no dude
Golf 1993 clipper
