No power to fuel pump 1985 GLI
(In Topic #234355)
I recently bought a non starting 1985 golf gli(cabriolet).
Hi!
I have spark and the engine starts with starting fluid but i dont have power to the fuel pump or a fuel pump prime. The relay is clicking when you turn the key and when cranking. My fuel pump relay is number 2 but the letter is upside down. I have changed the fuse and need tips on what to do now.
Is there one or two fuel pumps in these golfs?
And where does the wire from the puel pump under the passenger side go?
And behind all the relays which wire/wires go to the fuel pump?
Yes there are 2 Fuel pumps. One External one in-tank.
the fact that you are getting a click, tells me either you have a broken wire to the pumps, or bad Grounds.
If you haven't replaced your main frame to engine and frame to battery, It wouldn't hurt you test for a ground drop.
There is also the relay itself that may be bad, and to test if it is before the relay or after, you might want to jumper it out, or place the Horn relay in it position as a test.
If the relay runs the pumps all is good
Thanks! I will try some of the things you mentioned and come back here if i run into further issues.
Regional Host NE
pull the rear carpet up on the drivers side rear
there will a five wire harness three go into the
tank two will go through a grommet to the external
pump you will get the colours from there and you
will be able to check for power have harness lying
about if i find it i will get the colours for you
Regional Host NE
wires
Regional Host NE
tw0 with ring terminals external pump
Hello again
Today i took my horn relay and put it in the fuel pump relay position. When i did this(the key wasnt turned) i could hear the fuel pumps running. When i turned the key and did the same thing, nothing.
I will order a new fuel pump relay but could this also have to do with the ignition lock? I am a bit confused
Fuel pump will run all the time with the horn relay in.
Your fuel pump relay may be bad, but give it a go first.
You have eliminated the wiring from the fuse panel to the pumps.
Get the correct relay.
see the last page to get the proper CIS Relay
http://www.cabby-info.com/Files/Relays.pdf
If they still prime give it a go.
Now i have gotten a new relay and same issue, no prime or sound from the fuel pumps when cranking. I assume this could have something do the with the ignition lock? Or is there anything else that could stop power from going to the fuel pumps?
Regional Host NE
Re:
Welcome to the vw classic car learning curve one minute you are up there next minute you are totally frustrated and rock bottom step back think logically then you will sort the problem out using your own initiative good luckHugo Bäck said
Sent from my SM-G960F using Tapatalk
