Mystery wire in engine compartment
(In Topic #217790)
Unidentified wire
or from the ICM to the Hall Generator.
Maybe RubJohnny will have a better idea.
Current rides:
It acts as an earth for the some of the gauges in the cluster. Hence why your temp guage is all over the place. Without the proper earth the resistance to the guage is in correct.
A picture of the area would be useful
Ian
WATERNAIR said
I'd love to know the answer to this as I found a spare 2 wire female plug yesterday floating about near the servo and I dont remember removing it for the servo upgrade for anything
1985 I'm pretty sure that one isn't used on the later cabs.
On the early small block cars the brake lights worked from a pressure sensor onto the Master cylinder. In later cars there's a switch on the steering column above the brake pedal. Hence the redundant electrical connection.
You'd have thought they'd have changed the wiring loom over the years wouldn't you?
Ian
Ian
Makes sense, thanks for that
Oh and sorry for the thread hijack
Current rides:
The white plug with the yellow wires near the servo is for the front fog lights which VW did not fit to many cars so that is why 99% of the time there is nothing attached to it.
