My Clipper has goosebumps on the paint
(In Topic #231275)
Hi all, just took the cover off my Clipper to give it a warm up and noticed there are loads of small (maybe 0.5mm) lumps on the bonnet paint work. they sure as heck weren't there before. Its been sitting under a Halfords super dooper waterproof but breathable cover for a few months now
Anyone seen this before?
I rubbed my finger over one and they didn't go so I'm now concerned the paintwork is naff. It was near immaculate till i noticed this
Any ideas?
Any ideas?
You sure it's not water droplets not iced up on top?
Sent from my AC2003 using Tapatalk
Oh if its that I'll laugh my ass off. I'll go and check again once I've finished work
I personally would wait for a warm day, and let the sun hit it then check again.
Bubbles under the paint would mean to me that there wasn't a good water filter on the sprayer and or the filter wasn't drained or cleaned properly and the micro water has now surfaced as Frozen water bubbles under the paint. Seen it before on my clipper wheel arches and only the arches.
Let the Sun shine on it and see if it will go away In my case and I said in my case it was done prior to me getting the car, and I ended up having to sand prime and respray correctly and 2 coats of clear the rear wheel arches, after removing them and cleaning the underside and sealing it with a hardening under coat, prior to re-spray / clear of the arches.
It could be in the clear coat, but in my case it was the paint layer.
If it turns out that the latter is your issue and you paid to have the car re-sprayed then I would ask if the sprayer warrantied the work and that you might get a re-spray for free.
After one of my cars was smacked in the front the warranty was 3 years on the paint, after about 12 months I noticed a Fish-Eye in the hood… It was repaired (full sand prep, and re-sprayed for free.).
It sounds like what we call in the trade "micro-blistering".
As Brian's says, Caused by moisture in the compressed air supply when sprayed.
The only remedy is a sand and repaint.
Could you post some images so we can confirm?
I'm working away for a few days so will get some pics when i get back
Not surecif I posted,trying taptalk. But yes its a case of having to respray.. ive got issue on 1 of my bumpers. If you don't have access to warm garage maybe best to wait until warm days come back. Rub fill,smooth and paint. Then on with clear coat.
Sent from my SM-G960F using Tapatalk
On the drive
Myvalver 89 GTi Grey mk2 16v
Finally got round to checking again and their still there. Looks like it'll be off to the body shop at some point
Not a major problem as the running problems means it's under a cover all the time anyways
