Mk1 tonneau cover stud issues
(In Topic #213082)
Can anybody tell me where you can buy a heavy duty set from.
Thanks.
The Issue is that if you don't have the Die (the cap is placed on it on a firm Surface Cap cover with stud. then the top, and female receiver
The Punch is similar to a Roll-Pin tool, that is it has a centering pin. This pin helps with rolling the rivet from the inside to the outside to hold it. The Die keeps the cap from denting and looking smart. If you don't have the die, then the Cap can distort and when you are smacking down the rivet, the rivet actually pushes the Cap in and shortens the length of it.
They make a set of snap pliers that do the same thing. But alas for a one time job, they are expensive.
You could try taking your boot cover to a Auto Upholstery shop, to have the snap replaced.
similar to this:
https://www.amazon.com/dp/B00004T7VT/ref=asc_df_B00004T7VT5130976/?tag=hyprod-20&creative=394997&creativeASIN=B00004T7VT&linkCode=df0&hvadid=193987317966&hvpos=1o1&hvnetw=g&hvrand=17274254171126337193&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9010814&hvtargid=pla-309633177580
