mk1 tin top tail light connector (Y reg)
Hi all
Can anyone advise as to where I can purchase the connector that's attached to the tail light loom which connects to the light cluster.
Alternatively is there a work around as one of the blades within the connector that is crimped to a wire has snapped. I can get blade out but don't seem to be able to purchase one identical in shape hence trying to source the entire connector.
Thanks in advance
Craig
If you are talking about the whole socket, which is easily replaced as an assembly, there is a Delco (gm) brand out there with the dual pin (pad) connection for the tail/brake light socket cheaper than OEM, you will have to match the wires as the colors are different than the OEM.
AC DELCO, LS 140,GM 88860442,1157-2057 LIGHT BULB SOCKET
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
Hi Ian
That's the beasty, thanks.
Didn't even think to try werk.34, should of they stock a lot of hard to get bits.
Craig
