Mk1 GTi DX Distributor Shaft Seal
(In Topic #221114)
Just wondering if this is the wrong size, as the website lists this as 026 905 261, but when I check the online parts catalogue, it says 056 905 261 (which is the one Heritage list).
https://volkswagen.7zap.com/en/rdw/golf/go/1983-7/9/905-203000/#12
I know it should be reasonably tight to ensure a good seal, but surely it shouldn't be so tight it tears the seal on the way in (which it has done!!)
Anybody experienced this?
Cheers, Peter
did try just the rubber o-ring but it leaked oil when driving so fitted a new paper gasket as the leak has stopped, just make sure you clean up the metal faces before fitting the gasket.
I still have the O-ring fitted as well….
I'll try and find the paper gasket…..
Think I've found it… Part number 056905261 Is this the one you ordered?
https://www.vwheritage.com/056905261-distributor-shaft-seal-vw-spare
Last edit: by mark1gls
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Fengine-oil-leak
I've a load of o-rings of various sizes left in my gasket set. I'm working on the assumption that it is built to fit multiple models, and I've not made a grave error somewhere along the way. Will see if there is one to fit the dizzy.
On all my 90's that I have had to time on first new to me. I have had the issue where the o-ring is gooed and prevents the Dizzy from turning.
Which involved me in soaking the base in a Deep Creep oil and smacking the base of it to get it to turn.
As my 2h's didn't have a paper gasket under them I wonder if that aids to prevent the condition… All I know is that after getting them loose and applying a tad of Never-seize to the o-ring I haven't had any issue in leaks or moving the Diz on setting the timing.
Have to say, the help on this forum is superb, thanks again.
