Mk1 Golf Ultimate rear brake rebuild package
(In Topic #224204)
I am thinking of cleaning up the underside of the rear of my cabby. Take the subframe off, clean it and paint it. And look at replacing the bushes on the roll bar. (are these roll bars good enough to re-use? or is a new one prefearble). The current one seems in decent condition
Whilst im doing this i'm also going to replace the rea bearings, so was thinking of maybe doing the drums and the whole lot as seen in these kits. Have any of you used any of these kits attached in the links below?
Also, any other parts i shluld look at replacing as i'm doing this?
Thanks in advance
https://www.classic-vw.co.uk/mk1-golf-ultimate-rear-brake-rebuild-package-5393-p.asp
https://www.ebay.co.uk/itm/VW-GOLF-MK1-GTI-CABRIOLET-BRAKE-DRUMS-SHOES-KIT-C384-/220926390933
Don't get me started on how frustrating it was to change the rear shoes only to have the same side cable snap when I applied the e-brake….after buttoning it all up and back on the ground. I have never needed to replace the rear stub axle as a maintenance Item and if your aren't worn or bent neither do you.
I do not see the rear brake cylinder rubber hoses, as they need to be attended to. The Stainless Steel jacketed Teflon core ones are the cat's pajama's.
As long as you are replacing the bits get a hardware package that has the springs and shoe holder bits and a new parking brake wedge. They are only about 14 USD over here for both sides.
Taking the lower rear shock bolt out can be a right royal pain in the keister, and on new to me cars I have had to cut them out… Think Swaz-all…. Going back wrap the bolt from head to threads with Teflon tape, then slather it with Never-Seize and you will never have to cut it out again.
I have a how to on that with pictures of a bolt that is 5 years or so old that was wrapped…
How to Keep Rear Lower Strut Bolt from Seizing. | Volkswagen Owners Club Forum
Vic said
If you look on the second one I think they also do the flexi pipes (4) and clips. The other one to consider is the handbrake cable holders (mini coat hangers).
Naw it was the first one, I didn't read the description just looked at the pictures silly me…
buying the more cost effective version then adding hoses that you source SS PTFE are the best, and new clips will still be less than the more expensive one, and unless your caster or camber is way off on the rear, I don't think that the Stub axles are the way to go. I mean over the 20 years that I drove my Diesel, and the 15 or so on Cabriolets, I never had the need to replace the stubs. I did start really checking the setting on the rear after my Kiddies started to drive my Cabriolets….for beam and axle damage….when I would get it aligned..
I will try and source some brake cylinder rubber hoses. I dont want to be held up waiting for any parts…ive been there too many times! ha
