Mk1 Golf FashionLine
(In Topic #215571)
I've finally just got my cabby out of the garage I've had a DX engine fitted to my 2H cylinder head as my engine was knackered, I've just got it back and there is a crunching noise when I release the clutch ones it's in gear, also my engine in sort of rocking which I don't think is normal any ideas what to do apart from take it back to the garage 😂🙈
Go straight back and don't except no for an answer because in either case it simply isn't right! 👍🏼
Sent from my Smartphone 📱
The engine should not move that much …
No idea what that noise is???.
1st gear issue could just be badly adjusted gear linkage or not at all.
The crunching sounds like the clutch plate not engaging properly because of the gear linkage of selector badly adjusted.
I had that several times on a Mk1 Escort.
Dazrodge said
Iā€™m on my way back there now so hopefully it will come out running like it should be thanks guys
Good luck mate! 😉
Was the gearbox fitted to your old engine and did it make the noise before the garage touched the car?
If they forgot the engine mount did they forget to fit/tighten up bolts in or around the gearbox/clutch???
It's really hard to say what and where the noise is come from just watching a video clip, you could use a stethoscope to find the noise or I use a long screw driver and place 1 end in your ear and the other end in and around the gearbox and touch the metal surface and you can listen to the bearing etc and try to locate the noise.
Be very carful doing this near anything that is spinning as you don't want to slip and get the screw driver caught in anything spinning around….
Let us know how you get on.
