Mk1 golf electric windows
(In Topic #217900)
growing with information.
A1 Cabbie Power Window Problems | VW Vortex - Volkswagen Forum
Page 4 has what the cabbys controller looks like.
The inputs to the thing are 3 connectors that are keyed.
one for each window.
Posting pictures of what you have go a long way to helping us, as I don't have the Corrado's Bentley or Haynes to read the wiring diagrams.
I do know that that switches between the Corrado and the Passat are the same save for the rocker cover is "upside" down for the Cabriolet.
fusebox side of the loom you shoudl have black and/or black/blue which needs ignition live -> G spade 1, 2,3 or 5. brown/white -> door pin switch for interior light. red wire from fuse -> p spade. red/yellow ignore. fat brown from module find a good earth near by, bare metal a bt of bodywork and self-tapper will work if it wont reach anywhere handy
You will have power to the controller for 15 minutes after you turn the key off.
It was a Trick I found, that I was tired of forgetting to roll my windows up after I had gotten out of the car and closing the door.
So one day when I was diagnosing my windows, I started to look at the wiring, (it was a broken ground/power in the loom between the door and the "a" pillar.
Cutting the brown/white was a blessing….
Fortunately that it is only two wires, and a fish tape helps.
If you don't have electric windows, then you also may have to make a couple of new holes to get them to mount correctly, I even had to cut a larger hole for the window stop.
see the 2 pin plugs with the thick brown/red and black/red, these are the motor power wires. For whatever reason the corrado loom has the window plugs the opposite way round so you have 2 female ends. you need to find a male plug and splice it to the corrado loom, or the mk1 regulator
Before you solder the plugs check the windows work the right way round though, you have a 50/50 chance of getting it right the first time
