mk1 clipper cabby running issue
(In Topic #205904)
1.8L 32/24 DMTL EX engine
car turns over may start up but abruptly cuts out seems like fuel starvation, have replaced tank, filler neck, coil, ht leads, swirl pot, fuel pump, also bought another carb and still the same issue, could sometimes get it to run long enough to get down the road but then again acts like fuel starvation no reaction when you press the pedal. had a new dizzy and new coil also.
anyone????
Portsmouth based
thank you! I have done this now and the car starts at least and i can drive it but then it suffers from fuel starvation when i put down some power, then if i ease off it may carry on driving fine, and other times it drop dead usually when i push the clutch in, any thoughts?? I did not use a welding tip I had just used a cable stripper and bent a notch into the return pope.rubjonny said
remove the swirl pot if fitted, block the return and put the feul feed straight to the carb. if that sorts it refit the pot and put a welding tip in the return to act as a restrictor. common issue as the restrictor should be there as std but goes missing
it could be the fuel pump is a little weak though
rubjonny said
theres plenty guys on here who just remove the pot and forget about it
Thank you that seems to have sorted it for now!!
