Mk1 Ce1 VR6 conversion
(In Topic #238514)
Double checking wiring is correct
Hi
Sorry if this is already posted I have exhausted all my attempts to find a solution online so here goes.
https://clubgti.com/forums/index.php?threads/ce1-abf-splicing-of-looms-help.249714/
On the above link Rub Jonny said vr6 loom should be the same as the abf so queries below;
Ce2 (F/5) needs wiring to Ce1 (C/18) F/5 is blank?
I have wired all the other wires in as mentioned on that thread.
Below is my findings on my multimeter on the pins on the ecu connector (OBD2 ECU)
"-" means blank
Pin. Volt
1. 0
2. 0
3. 0
4. 0
5. -
6. 12
7. 7
8. 12
9. -
10. -
11. -
12. 0
13. -
14. 7
15. -
16. 0
17. 0
18. -
19. -
20. 0
21. -
22. 0
23. 0.04
24. 0
25. 0
26. 0
27. 0
28. -
29. -
30. -
31. 0
32. -
33. 7
34. 1.6
35. -
36. 7
37. 0
38. -
39. 0
40. 7
41. 7
42. 0
43. 0
44. 0
45. -
46. -
47. -
48. -
49. -
50. -
51. 0
52. 12
53. 0
54. 0
55. -
56. 7
57. 1.6
58. -
59. -
60. 12
61. -
62. 7
63. -
64. -
65. 0
66. -
67. 0
68. 0
Any help would be appreciated I don't want to connect the ecu and it go pop.
"-" means blank
Pin. Volt
1. 0
2. 0
3. 0
4. 0
5. -
6. 12
7. 7
8. 12
9. -
10. -
11. -
12. 0
13. -
14. 7
15. -
16. 0
17. 0
18. -
19. -
20. 0
21. -
22. 0
23. 0.04
24. 0
25. 0
26. 0
27. 0
28. -
29. -
30. -
31. 0
32. -
33. 7
34. 1.6
35. -
36. 7
37. 0
38. -
39. 0
40. 7
41. 7
42. 0
43. 0
44. 0
45. -
46. -
47. -
48. -
49. -
50. -
51. 0
52. 12
53. 0
54. 0
55. -
56. 7
57. 1.6
58. -
59. -
60. 12
61. -
62. 7
63. -
64. -
65. 0
66. -
67. 0
68. 0
I would send RubJonny a Private message on this forum or clubgti. He is a very helpful chap .
