mk1 campaign
(In Topic #222611)
how to tell if its a campaign model
hi how can i check if my mk1 golf is a campaign model.cheers
There's a very specific guide on the forum somewhere but it'll have Pirelli P-slot alloys (14" with part number ending in 'A'), leather bound steering wheel rim, EW chassis, sunroof, dimpled door pins and it'll be late 1983 registration (I think Aug 83 or later).
But all parts are easily changed, apart from chassis no.
and sun roof…..
Website Manager
hi mine is a y reg which is an 83 plate it has a tilt and turn sun roof .interior light on passenger side because handle for sun roo is in the middle .my chassis number has a dw in it not a ew .so does this mean 100 % its not a campaign model.it has different wheels over the years and other parts .
Doesn't sound like a Campaign. I wouldn't worry about it though, there's no difference in the cars themselves they just have a few run-out options added to help them sell before the Mk2 came along. The most important thing is you've got a Mk1 Golf GTi…..which is awesome
chassis can be DW or EW, the important part is the correct option codes on the boot sticker and factory fitted sunroof.
fact yours has aftermarket one tells you it wasn't a campaign
hi mine has a factory sunroof coloured the same as the car.there is no sticker in the boot .so there is no way of telling for def if its a campaign model its also lhasa green.
factory sunroof is a metal slide only, if its a metal tilt+slide its a scirocco/audi replacement. if its a glass one then its dealer fit
If the boot sticker is missing you can apply for the birth certificate:
https://clubgti.com/forums/index.php?threads/applying-for-your-volkswagens-birth-certificate-link.211662/
