Mk1 Cabrio standard rear lights wiring
(In Topic #234549)
Car currently has aftermarket crystal clear lights on it.
Have bought a set of original rear lights.
Does anyone have a wiring guide for the original lights? Aftermarket have a wire to each bulb (coloured) and a black ground for each bulb. Nit quite sure how to connect all these up on all the old spade tabs on the original light set i have!
The the power to each bulb is colored.
yellow square is the common ground I usually runt it to a Bumper bolt for each side.
Are the above diagram coloura correct for the car loom?
The central plate is the ground for all bulbs, an you only need one ground wire tied to the bumper bolt.
The original configuration is that the left was tied to ground and the ground for the right came from the left.
Using a separate ground for the left and right makes it more reliable.
