Mk1 cabrio - 2.0 16v ABF conversion - engine judder (~3000rpm)
(In Topic #211587)
Okay, so I've tried changing the ECU relay and even by-passed it all together to see if that helps. No real difference noticed, although oddly i forgot to plug the wire that i have bypassing it in once and the car still started and ran as if the ecu was powered (what have i done wrong there i wonder )
Ive also tried bypassing the fuel pump relay, again with no real difference noticed!
Any other areas i should be looking at before i give up and push it on someone who actually knows what their doing!?
Oh and its also had a new crank sensor, as prior to this the engine would sporadically cut out!
remove the tape from the tps/idle switch harness behind the inlet, it bakes hard here.
where have you put the ecu vacuum line, and is it exactly 1 meter long.
