Mk1 Cabrio 1982 engine starts aleatory
(In Topic #205810)
It starts, now it doesn't, it starts, next it does not....
1982, 1600cc injection engine, all re-done.
Everything is new except for the engine block !
Injection was refurbished in Germany Bosch Classics.
Works well, runs well, BUT, once I stop, in a few minutes it will start OR NOT !!!
It's so annoying….
Been to a Bosch Car Service where they had an apprentice…. and this boy in a few minutes cut and broke a lot of stuff before I manage to have him put aside from my car.
After that, engine starts and stalls….. been to other 3 places and no one knows what to do…
Does this happen to anyone ? Any hints?
All best
Oca
The accumulator is a sort of valve which holds the fuel pressure in the system so makes starting a warm car easier.
Did the Bosch service centre not pressure test the fuel injection system or was they looking for a computer port to plug their laptop in to…
Once I assembled a new petrol pump, and started it for the first time after some 10 years….. drove it to this Bosch guy and noticed the car was leaking petrol. There with the car up, noticed it was from the accumulator back bolt. The guy there did not know what an accumulator was and took the tiny bolt and put some sealant on it. Leak stop……
Gonna have it checked now, hope you are right and car gets well, to serve for another 10 years, minimum…..
thanks
Not sure if it will work with out an accumulator as you may still be getting the same problems you are now.
Accumulators do seem expensive to buy new but they are fitted to a lot of cars running the k-jet fuel system, eg. Audi, Porsche, Saab, Volvo so that my widen your search.
Have you also checked fuel filler neck for rusty holes, fuel tank for rust and dirt.
Old fuel also goes off after about a year.
Shouldn't ask that, like my old doctor used to say, "if it is there, it is supposed to be there…' I'll look around to try to find a reasonable price.
Thanks a lot
There was a thread on this site.
With the £ dropping like a stone and the UK leaving the EU it may be a good time to buy one from over here?
http://www.ebay.co.uk/itm/0438170052-BOSCH-FUEL-ACCUMULATOR-K-JETRONIC-BRAND-NEW-GENUINE-PART-/152016789140?hash=item2364e81e94:g:sIkAAOSwv9hW6FJo
Found the thread.
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Fleaking-fuel-accumulator#post_1538330
Last edit: by mark1gls
Could not fix it problem went on 3 yr many garages and people Tried all sorts we advanced timing right up was only way some times would start most time you had leave it 20 mins changed every mortal thing all injection system dizzy coil done the head
In end got sick just fitted 2,0 abf now it's perfect
Got the new fuel accumulator and the result was the same !!!
Engine starts well in the morning, when cold but as soon as you stop after warming-up, it does not start, only after some minutes waiting.
Mechanics (so many now) can't tell what it is.
Could it be something with warm starting, cold start valve or air-regulator?
Anyone?
Óca
