Missfire on the 4th cylinder
(In Topic #241477)
I have to note that the misfire seems to be present at iddle and particulary when the car is warm (present at cold too but less perceptible). It "pops" in the exhaust (less when cold) and I can see the rpm drop when the "pop" occurs. Under load or higher rpm, it seems to disappear and the car runs great. The spark plug from that cylinder seems to be a bit wet too but the others are fine.
I don't know why but when I play with the ignition timing, there is more or less missfire but it never disappear.
Anyone have any ideas on what to check next or what the issue is ?
Sorry If what I wrote is incomprehensible, english is not my first language and I'll happily re-explain myself Thank you.
I used to love Bosch Triple Plat plugs.
But alas, I had my Cabby develop a miss. I couldn't find it. As my plugs were about 2 years old, I decided to replace them with new Bosch Plats.
I will be puzzled that it got worse with new plugs.
So I bought a new set or wires as well as Cap and rotor.
It was even worse.
So I started to get back to Original condition, the old wires and plugs couldn't be matched and now I had intermittent spark on 3 plugs.
My daughter showed up in my other Cabriolet. So I took the cap, leads, and plugs from her car and placed them in mine. Wally, it was running again like a graped ape.
Speed forward, I fond two bad plugs in my "new set" using a Ohm meter they were opened. So I took them back and the next set had 2 bad plugs as well. I decided to Switch over to NGK BP6ET Measured the resistance and all was fine. Placed them in and I had flaky issues but only on one cylinder.
Found that my Original issue was a bad plug wire on the number 3 cylinder. Compounding it was that I added two bad pugs in different cylinders as well as the original plug wire that was bad. So the new set had 2 new plugs that were bad. and I got a bad set of new wires.
So new parts aren't necessarily good parts.
So from then on I used my DVOM to change plugs by measuring the resistance of them. Then only changed plugs, start the car, then wires. If it wasn't for my set of good plugs and wires off my Green Cabriolet, I might still be working on the blue one to this day, as I kept introducing issues with new to me parts.
I did notice that my NGK plugs made my rides Peppier, so I stopped using Bosch anything and Started to rock only NGK plugs. They make wires now, and I wouldn't hesitate to use them as well.
What I don't understand is why there is misfire on only one cylinder ? It can't be the dizzy because I would get misfire on all the cyl. Right?
Or maybe the rotor arm doesn't rotate perfectly and there is a litlle bit more gap between it and the 4th leads than the 3 others ?
Website Manager
I did not check the spray patern and I didn't controled the pressure. I assumed it could not be part of the problem since a bad metering head would cause missfire on all the cylinder. Correct me if I'm wrong. And for the injectors I replaced them with new ones and nothing change compared to before.
I also saw on other topics that the fuel line could rust or get dirty. Would that cause a misfire ?
Website Manager
Worth checking the injector o ring at the same time, as you may have pinched it and it is leaking air into the 4th cylinder. Check the injector seat is not cracked as well.
Website Manager
