Master Cylinder HELP please
(In Topic #233661)
I brought a G60 used servo and master cylinder set to upgrade my brakes with and also brought a new master cylinder.
Unfortunately when it arrived I worked out it was from an ABS vehicle and the master cylinder fitted only had 2 outlets. No problem I thought I have a new one to fit anyway.
The master cylinder mounting position on the one I took off are not horizontal like the original mk1 golf or like the new mk2 cylinder it purchased the whole unit mounts on about a 30 Degree angle.
I am looking to see if the G60 (or other vw like transported) used this angled set up with a master cylinder that has 4 outlet ports for non-abs type cars. I really don't want to be adding loads of 'T' pieces to the braking system if I can help it.
If anyone knows a part number or can post a web link it would be really helpful. I have googled it but cannot find anything clear about which ones come with an angled mounting position vs a horizontal mounting position.
This is pretty much the last piece of the jigsaw to getting me on the road again after some serious delays with parts and unexpected welding.
Craig
I need the 4 port version of this.
If anyone can help.
Does not matter if it is 22mm in place of the 23 mm this is.
Regional Host NE
