Locks and dowels Mk1 Golf Cab 1989
(In Topic #224195)
Locks and Dowels
I've read post about the lock barrels.
The background
My Mk1 Cabrio 1.8 GTi (1989) didn't have a lock barrel in the passengers door so I've managed to source a door handle with the lock barrel however it did not come with the correct key! So I'm hoping to match the barrel to my existing key that operates all the other locks however I can't find the lock dowels anywhere - is anyone able to help or advise?
Any assistance would be much appreciated.
Mani
1, Take the barrel out of the door handle and fit the key into the barrel. File off the protrusions and re-fit. It should then work with that key. Problem is it will also possibly work with other keys.
2, Buy a few old locks and take them all apart so you have a selection of wafers (the little dinky things in the barrel) and then just keep trying them in different orders until something works.
Those are the 2 methods I've used in the past.
Someone else might have a different idea though
Ian
Manish
borednow said
Theres a couple of ways
Ian
No, just a pictorial I had only 2 locks that had to be re-keyed, and it was the one on the trunk where I had to file one of the wafers a wee bit.
http://cabby-info.com/Files/RepairingDoorLocks.pdf
Again thank for the advice - I'm trying to source some locks 🤞 as I can't get the dowel kit as it seems to discontinued…
https://www.classic-vw.co.uk
See if these guys have a set or if someone is breaking a car complete with keys/locks.
