Light bulb for ashtray and heater control panel?
(In Topic #228178)
Can anyone confirm if this is the correct part number for the light bulb N 0177512 also where could I pick some up from?
Also how do I connect spades to this so it clips in? (For heater panel)
I've found an old thread that confirms the parts, but I have the later heather control fascia so not sure if the bulb is suitable for that
Last edit: by optimusdub
There were two styles of heater fascias one was a Bulb that was socketed, the other was part of the fascia.
The socketed type was on the Scirocco.
There are threads on how to replace it if it is the fixed type.
For the ash receiver, I just swapped it out for a LED, had to tape it on place but it worked fine.
88 Cabby Heater Control With Non-Removable Bulb ... Mod? | VW Vortex - Volkswagen Forum
Brian! That is awesome, great help! Thank you 😊
Match them to these, they also do LED which may have a direct replacement ?Replacement Dashboard & Panel Bulbs for Cars
Last edit: by Early-1800
Thank you all for the feedback. I ended up buying these
https://www.ebay.co.uk/itm/381597382921
Seems to do the job for now! Thanks
