Lift pump into carb tank.
(In Topic #214981)
I'm starting work on my swallow. Working back to front so want to sort fuelling.
So do any lift pumps fit into carb tanks? Or am I better off sourcing a gti tank and pumps?
Swallowtails usually didn't have a lift pump, and was only added after the introduction of the GTI series and CIS fuel injection that HARD TURNS and low fuel presented a fuel starvation issue.
Swallowtails should have a 10 Gallon tank and a Full sized spare tire. Where the 84.5 models were converted from 10 gallon tank to 13, and a space saver spare tire.
So be cautious as to which type of tank you may purchase, as well as most aftermarket tanks don't have a internal swirl pot or baffle inside of them.
I'll be fitting an injected engine of some sort in the bay.
Jump to my later 89-90 Cabriolets, and I have an external swirl-pot/sump/filter that is attached via a clip to the side of the tank (right side) with a in-tank lift pump.
The 84.5-93 Cabriolets had a change to the body that shouldn't be on your Swallowtail so I don't know if the sender from a later would work on the early. The difference is that the senders went from 2 wire to 3, with the 3rd wire was to power the lift pump.
Cheers for your input!
also all G40 shape polos have a lift pump that fits, and the same swirl pot under the car. only difference on the lifter is the plug points straight up, so it can make clearance a bit tight for the connector. ideally try to get the angled rubber boot off the donor.
Cheers for that!
