K N air filters any good ?
(In Topic #215384)
But as a cone filter looking for a COLD Air Injection, and unless they are ducted to the outside air. When you let them free flow engine compartment air, then the average temp of the engine compartment, they will ingest over 130 degree air.
I pop the cover off now and then and remove large items like leaves, bugs but I've never felt the need to service it yet but I will next spring.
As for performance, really?
We're talking about 99% of MK1's are for road use.
Ok yes K&N are one of the best when it comes to racing and it makes a small difference but that is not the case here.
I bought it because it's good for 1,000,000 miles or so they claim.
(as if any of us are going to test that theory) 😂
Ultra low maintenance and over time a money saver.
You might gain a tiny bit on mpg as well. 😉
Sent from my Smartphone 📱
BAZ-GTI said
Might give it a go will order a recharge kit and give it a clean up and re-oil it and stick it in, I read about the 1,000,000 miles like you said we won't test it to that, but will see how it goes as i did get it for free, its used but once cleaned it should be ok and see how its goes
Service it by the book and you'll be fine for the time you have and the next 10 owners at least, it could live longer than the lifetime of the car! 👍🏼
Once at after about 100,000 miles and again when I swooped my engine over and I had the air box out of the car, it does take some time to clean, wait for the filter to dry and re-oil it.
I do get it out the air box when I change my fuel filter (makes it easier to get in the air box on a Gti) every 2 years and give it a bang off and empty any leaves etc out of the air box.
The new filter will come pre oiled so you don't need to do anything to it, just clean out the air box and pop it in.
Well worth buying if you are keeping the car as it will pay for it's self after a few years, I can't say I notice any difference in performance, the main advantage is it's just such a pain getting into the air box with the meter head etc on top of it so I don't have to change an air filter every year.
