Indicators
(In Topic #226808)
The rest all work fine and strangely when I connect the spotlight feed it lights up but won't flash with the correct indicator feed connected.
I stupidly thought I could just run a new jumper wire from the black indicator wire on that side …. it does now work….. but when I turn the lights on the indicators on that side don't flash at all.
I will remove the jumper wire later today but still a bit lost as to why its not working.
Any help appreciated
Sent from my SM-T720 using Tapatalk
Indicators
Indicators
Indicators
Indicators try cleaning contacts on relays,fuses and stalk.
crazy things these old cars…temperamental
On the drive
Myvalver 89 GTi Grey mk2 16v
Re:
Thanks I'll check that tomorrow, I checked the power to the horn and it's all good so I had a feeling it would be an earth issueKenneth Cartwright said
Horn will be the earth cable to steering rack… probably.
The indicator thing is a bit more strange though, they all work apart from the side repeater, I checked it using the spotlight plug and it lights up when I flash so the wires are good with no breaks, the contacts are clean and I checked them for flashing and it all works…puzzled
Try putting warning ⚠️ hazard switch halfway.. its also a dodgy thing that needs replacing.
Hopefully will identify the fault
On the drive
