Ignition live
(In Topic #232446)
The switched feed is located best off the back of the rear window defroster switch.
Ignition live is for the presets and keepalive for the clock and things.
If you source a Soche or Metra radio kit, that is the easiest way to hook up a new radio.
As you plug the kit in to your existing looms plugs, then solder/heat shrink the radio connector into the other half.
Like ;
https://www.partsgeek.com/934zbx6-volkswagen-jetta-radio-wire-harness.html?gb=pp&cid=28884375&aid=4168799374&kid=1100003048986&msclkid=1d3c95949abf15639965f5c00ad49205&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%28BSC%29&utm_term=1100003048986&utm_content=Volkswagen&
