Hydrolic Roof Issues!!
(In Topic #228119)
Another Mk1
Ive just bought another Mk1 K Plate Conv, with Roof Issues.
The pump works no problem if I feed it direct 12v in boot.
Opens and closes, But from switch in bottom console upfront I gets nothing.
Ive checked the fuses at fuse box, and nothing, they all not blown.
The Relays in boot look all clean with NO signs of corrosion whatsoever.
Swapped the switch itself over with the L/H elec wind switch, works fine.
Can any of you please point me in the right direction on what to look at next?
Want to get all these little bits sorted before I get the engine transplant done..lol
MJ
MJ
@DjMj73
@DjMj73
Steve1973 said
Are you using the right procedure? Key in ignition but not turned.
Yes sir..
I just tried it again.
MJ
@DjMj73
@DjMj73
as the e-brake has to be fully up and engaged on the ones over here.
Steve1973 said
Next test I would do is to check for power on the red wire to the switch.
Voltage drops when pressing..
MJ
@DjMj73
@DjMj73
Steve1973 said
Are you using a multimeter? What's it dropping to? Are you testing between the the red and a good ground.
Yes Steve, for some reason when checking voltage was going up.
When hitting the switch was decreasing down below 8.
One relay in boot was clicking when ign goin on.
Its a new relay that previous owner had replaced.
Honestly can all relays just break down?
Is one relay out the 4 making it not work.
Noticed few wiring issues when I pulled headunit out, someone has ran a feed from the immobilser to stereo, red pos wire has been cut, brown red stripe x2 cut.
MJ
@DjMj73
@DjMj73
Briano1234 said
Check the switch on the E-brake.
E brake?
MJ
@DjMj73
@DjMj73
Steve1973 said
Join the brown/reds together. If I remember right it is a switched live for your radio and continues on to the fusebox for your roof.
Will do mate, and thank you.
Hope this sorts the issue.
Dunno why peeps cut all the wires if they dont know what there doin!!!
Mj
MJ
@DjMj73
@DjMj73
Hi Steve,
Got the Roof working.
Thanks for all your input in regards to this.
Found a couple of fuses blown aswell, all replaced.
Ign Switch is playing up as well now so ordered a new one.
Once again thanks dude.
MJ
MJ
@DjMj73
@DjMj73
