Horny?? Need help with horn issue
(In Topic #220519)
Hi everyone,
I am working on a mk1 caddy trying to get the horn to work, can anyone tell me where the live to the switch/steering wheel can be found?
When the steering wheel is fitted there is no live to either of the two wires which connect to the horn button.
I don’t know the history of this truck but suspect it had a different steering wheel at some point, now has the original steering wheel on, but is there something missing I wonder
The issue with your horn is that you are missing the wiper finger off your turn signal stalks with out that you won't be able to contact the slip ring on your wheel.
See the little brass finger at the bottom of the stalk.
So it appears that a new turn signal switch is in order.
Thanks Briano, you are a star ?!!
