Horn location in engine bay
(In Topic #232135)
Any images ?
That's where it is on my 1988 cabriolet.
Ill try and get a picture tomorrow for you.
Last edit: by mark1gls
Note from the factory the horns are +ve and earthed at the steering column/wheel
Early-1800 said
The twin horn setup was suspect when new so the one you have is prob a bodge to fix non working originals.
Not so, the +12 is to the horns via the fusible link along with the black/yellow wire, and direct to the battery.
The ground is via a Relay in the fuse panel that is provided by the Major Earth traveling up to the stalk from the wire on the steering rack gear box to the frame of the Steering rack mount, then through the button on the Wheel, back down the shaft via a wire to the fuse panel, then to the horn relay to Pick the relay, that applies ground back out to the horns.
The horns are attached on a Cabriolet under the Battery on a bar mount that is bolted to the frame horn.
https://www.ebay.co.uk/itm/GENUINE-VW-MK1-GOLF-CABRIO-SINGLE-HORN-MOUNTING-BRACKET-VAG-Caddy-Jetta-Scirocco/312368660750?hash=item48ba9f810e:g:XBMAAOSwE~ZcEBtC
Regional Host NE
Regional Host NE
Regional Host NE
